PPE ported fuel fitting vs stock Pics.
speedy03
Nov 19, 2007
47
Avon Park, FL
Here are a few pics of the PPE ported fuel fitting vs the stock one. The easiest was i found to remove it was to take off the A/C compressor. It came off very easy. I used a 17mm wrench to take the fuel line off, and a 7/8 socket to remove the fitting.
Stock one on the left. PPE one on the right.
Stock
PPE fuel fitting.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
What exactly does this do?
Larry, it helps the rail recover a little quicker. Bigger hole to get it in faster type deal.
The hole in the PPE valve in the picture looks way HUGE. I don't memmer the hole in the valve i got or did i drill it? It wasn't that big IIRC.
Thanks for posting pic's speedy.
9,903
149
Why would GM make the ID of the stock one so small??
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
smaller hole holds pressure better.
Kinda like suckin and blowing through a straw, kinda tough. Also kinda like the fill up the air balloon and let it go thing, i think it's an engineering balance between available volume and pressure retention.
I may be dopin' smoke on this one I aint no engineer.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Which one are u guys replacing the pass side or the drivers side or both?? I got one of these with my ats dual cp3's but didnt install it. But i noticed on my spare engine that both are small like that?
