Oil pump?
skintback
Take this one to church
Mar 5, 2007
926
Florida
I was looking at the DPR oil pump but i'm a little on a budget and time is running out so i was told to just shim my stock one if i only plan on making about 750 one day :rofl: so my question is how many shims does what for psi on the stock pump and do you do anything to the reg it's a DD what do y'all think?
slowlmm
Mar 2, 2008
2,582
47
so cal
I beilve you would only shim the regulator. I know nathan has done it with a stock pump and regulator and said he got about a 15 psi jump not sure how many or what exactley he did. i would like to do the same thing as well.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
I shimmed the relief spring on mine. I did notice a jump in max pressure but not hot idle pressures.
exactly. If you shim the stock pump you will NOT see an increase in hot idle pressure. BUT as soon as the RPM's come off idle, the pressure rise will be a lot faster and the max pressure will be higher (as S phinney said)
ben
ripmf666
15,123
14
49
Wentzville Mo
I think I will leave mine the way it is stock.30 to 35 warm idle and 60 to 65 running down the road, At cold start up its almost 70 psi.
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
Good thread! I was wondering the same thing. I had thought of shimming mine and doing some work inside to improve volume.
IIRC, min factory hot idle psi is 14. mines right there and any improvment is welcome. Prolly no easy way to up idle psi?
Bluemax
Sep 25, 2006
846
Missouri
Just an FYI... On cold mornings (about -5*F or so) a shimmed regulator will blow the o-ring out of the oil filter if it's not plugged in all night long to keep some heat in the oil, and it'll run well over 100psi in the process. :mad: I tried several brands of filters and wound up putting one on tight enough that I broke the filter wrench while tightening it. I wound up going back to stock and inventing a few new cuss words while trying to get the filter back off. :)
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
I really dont think its worth it...what we want/need is higher HOT IDLE oil pressure, which shimming the pump will NOT fix.
just my own opinion
ben
skintback
Mar 5, 2007
926
Florida
I read about the oil squirters with a ball and spring in them that only open at X psi what about taking the ball and spring out squirt all the time or will that drop oil pressure to much at idle
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
Drops pressure to much... its like having 8 oil leaks. If you had a big pump it prolly (total spring removal) could be done but not with a stocker. If the stocker is barely getting by why increase the need for volume?
TONS of people have done 600+ with a stock pump. You can to. If something fails with an oil pump mod the money you invested is flushed. BTW- Call Curtis he tried all the stuff your talking about on Boats/Cars/Trucks etc.. he actually did it/tested it. I was just farting around with washers.
Take a look at your squirters they can be opened up a little.
skintback
Mar 5, 2007
926
Florida
Did you take the ball and spring out of yours and opened them up with the DPR oil pump i take it will handle 8 open oil leaks all the time
S Phinney
4,008
Quncy, Fl
I used a stainless washer. I think it was a 6mm washer that was about .035 thick. Curtis told me to do it that way. The billet pump wasn't avaliable at the time and is usually not recommended for a DD.
skintback
Mar 5, 2007
926
Florida
Just to let some of you know what i did on my small build with the DPR high volume oil pump. I drilled out all 8 ball and springs in the oil squirters and so far added no shims to the relief valve it runs 110-120psi on a 38* start up and driving down the road hot runs 65-70psi now hot idle is only 25-30 not to sure if this move was good or bad i am still running the stock oil cooler may change that out one day just though i would share my findings so far got 4800 miles on it.
Sonny
LBZrcks
Jun 2, 2007
5,297
12
40
SoCal
Sonny
What kind of oil are you running?
3,422
Sonny, it looks like you're going to need Jon's new pressure relief valve setup.
Good to hear the motor is treating you right. When are you going to the track next?
