Oh really? Another good trick to know....thanks wana!
Disregard what I said....you should be able to set it up with an air pump and good gauge off the truck, then install it.
Sorry about that!
Nice write up JohnBPU stands for Basic Performance Upgrades. These are modifications that don't require engine disassembly. Here is my list of basic power mods:
1: Tuning - EFILive, PPE, or custom EFI Live tunes. To get over 500RWHP I recommend EFI Live tuning done on a dyno. Every truck is different. What dynos well on one truck may not on another. Don’t over look canned tuning as it might get you there.
2:4" exhaust with no cat front pipe and high flow muffler.
3: Lift pump - While some might be able to dyno well with out it is best to have one. It will help your CP3 live and will help you sustain rail pressure
4: Intake - A good aftermarket intake will help. I don’t care for the stock LB7 intake. I don’t care what the tests say. They dyno says my K&N FIPK made more power.
5: Gages: I recommend at least a boost gage. EGT and fuel pressure gages are nice.
6: Boost valve. Like the PPE valve can help. You want to get to 32 psi of boost on the gage. Some need the valve to get there some do not. Be careful the stock turbo will go boom at over 35psi pretty easily.
7: Auto Transmission upgrade or Clutch upgrade - The stock Allison will hate you at over 360RWHP. A good converter and internal upgrade kit is a must IMHO. The stock manual trans clutch is barely good for stock power. The Dual Mass flywheel is junk. You will want to upgrade both. Currently the only upgrades are from South Bend Clutch. A single disk will hold but for only so long. I recommend a Dual Disk.
by passing the ficm will allow you to run more pressure to the CP3 also. But you will have to find a "presidential solution" for running fuel through it to keep it cool.![]()
What does the Ficm have to do with it? It is just a pipe that flows through the case?![]()
Looks like we should probably add Michael's modded turbo inlet to this list.
you dont need down pipes and uppipes for 600HP you need a turbo and those or nitrous. I have 600+HP with my truck it wouldnt be possible without the turbo.
Guys, running insane lift pump pressures is pointless. All it does is increase the return rate from the CP3. There is an internal regulator inside the pump that regulates case pressure, anything above that pressure just becomes return to the fuel tank.
