Ill bring my drill tomarow kat and a couple anchors we can put tht sucker back up![]()
looks good.
the newer, revised angle should allow for easier viewing of stuff in the back.
Lordy, Lordy.
They put a 200lb oak wall cabinet up with 6 drywall screws in the back panel. Into the drywall only. They missed the studs by 1 inch on all of them. No mount plate, no top screws, side screw or bottom support. Basically the same way you might put a picture on your wall. Only the fact it was "wedged" into the walls kept it up.
What I don't get, is that they had to know they didn't hit the studs. You can certainly tell when you put in a drywall screw if it misses. And even then, how would you expect to hold a large cabinet up with just 6 small screws?
For now, I ran 12 screws into the studs, and 3 "toggles". It's not right, but it will hold.
I'm not a happy camper at the mometI use them for linens and towels. Probably wouldn't have even lasted the 10 months they did, if I have put anything real heavy in them.
I should have got suspicious when I saw them working:
The guy would pick up a nail, look at it, then throw it in the trash. Pick up another, look at it, then hammer it in.
I ask, "what are you doing?"
He says, "Some of these nails have the heads on the wrong end".
Then the foreman says, "Take those out of the trash. Those are for the other side of the cabinet."
They probably forgot their left-handed hammers too...
I have one
