Dry pop and cross thread everything, it'll never come loose again
I found something on Amazon that should work. There’s other options out there, but they’re very spendy and you’re gonna have to hack them up. There might be some other options out there, but that’s all I’ve gotten so far. I’ve also thought about somebody cutting mine up and doing a bunch of pie cuts to tighten it up.That is how my Intake is positioned. A shorter boot might help. It is a bit of a PITA to change the filter. I was thinking about changing mine because of this. Where did you find one with a shorter radius?
I don’t know how critical is, but I would think at a minimum you would want it in the center of the bend not to the inside or the outside where the airflow is gonna be faster or slower. That’s right where HSP built the kits with if.I thought the MAF was supposed to be in a straight section or the readings will be all over the place. Or hard to calibrate
I have an HSP Kit for my LML. It looks almost identical to yours. I did not have a problem tuning the MAF. I would run the intake that came with it.I don’t know how critical is, but I would think at a minimum you would want it in the center of the bend not to the inside or the outside where the airflow is gonna be faster or slower. That’s right where HSP built the kits with if.
