2002 LB7 pinouts
702Lb7
Sep 1, 2025
Nevada
Does anybody have the correct pinouts for FICM, ECM, and fuse block for a 2002 lb7? I can only find the ones for 2003 and up. Chasing a crank no start and have narrowed it down to something electrical. pin 30 on my ignition relay is not hot key on or off and pin 86 87 on the same relay are always hot. Trying to back probe the harness and all connectors to hopefully find a short, Thanks.
702Lb7
Sep 1, 2025
Nevada
Update on what I’ve found, fuse block tested bad ordered a new one( used on eBay) and it was also bad so waiting on another one. Stumbled across the main battery negative cables showing 12 volts to ground when disconnected from battery. Eventually found that when taking of the red feed wire from the top right stud of the fuse block that leads to the cab, voltage went away and cables were ground again. After a lot of tracing and unplugging, found that my electronic brake controller was causing this weird 12 volts backfeed to ground cable and this purple connector for the BCM was heavily corroded.
3,058
The controller back by the spare tire? That one has been known to get water in it and do as you describe
702Lb7
Sep 1, 2025
Nevada
I unplugged the actual remote/controller that is mounted under the steering wheel or just above the pedals, like I said just waiting for the new fuse block to come in hopefully I found the issue and no other problems.
702Lb7
Sep 1, 2025
Nevada
Can somebody please tell me if the relay pins for ignition1 relay is switched making pin 87 constant feed and pin 30 is the output instead of 30 being the input and 87 is the output on a 2002 lb7. After getting yet another block I am getting the same readings I doubt I got this many bad blocks in a row
