Tech 2 VATS relearn
Cougar281
1,962
384
St Louis, MO
Does anyone here have a Genuine Tech 2 on the current/final version (33.004)? I would swear there was a way to do a VATS relink using a Tech 2, but I can't find it for the life of me. From doing some searching, there's supposed to be somewhere that you can select setup, and if it's missing it could be a clone (mines not, but the image on the card is of unknown origin). Does anyone have an option to do a VATS relink in their Tech2 or am I crazy?
3,058
I don't have one. Only using Google
Have you checked:
Diagnostics > Body > Special Functions > Theft Deterrent or VTD > Program Password or Relearn
Cougar281
1,962
384
St Louis, MO
Have you checked:
I hooked up a BCM that I had programmed with the same calibrations as my truck and my original LLY ECM on the bench and went looking on my Tech 2 and all I have is this:
I'd swear I've done it before. But I can't find it anywhere. I could just be sofa king wee todd did lol. :ROFLMAO:
Even connected to my truck there are no options for it, so I don't think it's something missing on the bench. It just doesn't seem to be there in my Tech 2.
1,617
Is this what your looking for???
VTD VEHICLE THEFT DETERRENT???
I think you still need SPS function.
On the radios I usually just reprogram them and it works. But there is an option to put the new vin in them as well.
Cougar281
1,962
384
St Louis, MO
I don't think so... I do have that and tried it, but it failed on the bench due to no VTD module. If SPS/TIS2000 is required, then definitely not. EFILive can do it. What I'm referring to is the scan tool version of the 30 minute relearn procedure.
1,862
If it's an 01-05 truck I always just plug in with EFILive > F4: OBD > VIN Change > I hit "Retrieve VIN" and copy it to "New VIN" and also click the "VATS Relearn" button set to 0 cycles.
This has worked wonders and is also what I do on every bench flashed module I do.
