For some reason I thought it was 1/8mi, did they run the full 1320 last year?It’s an interesting class. What does everyone think it will take to win this class. I’m expecting to see the fast guys breaking into the 9s and a lot of low 10s.
48re would be your best bet at that weight IMO that isn't going to set you back your first born child's college tuition.I do believe it is 1/8th mile. We have heavily discussed doing a different transmission. We have 2 issues, time obviously, the truck is completely apart and we are 4 linking it, doing coil overs in the front, and putting a cage in it, and the other part is the cost. I can't imagine it being very cheap to do a 48, 4l80 or th400 lockup for a decent price. They are all very expensive when they need to hold 2000ftlb and 6000lb. The minimum weight is 6000lb.
What kind of power do you see these guys making on this turbo with no "extras"?Low to mid 9’s I’m thinking.
Jeff Dean has no love lost for him eitherThe fondest memories on CompD were those guys riding him every chance they got. That and Josh driving 4 or 5hrs to go kick his azz
I know several of the dodge trucks are 5.3-5.5 1/8th maybe little faster in their normal setup.We calced about 1600-1700hp to the ground with the Race Cummins that I had helped build. And that truck ran in 8.9 in the quarter at 160 miles an hour. That truck weighed 6000 pounds on the nose with the driver.
So my guess would be mid nine to high nine
If they are going faster than that, then they are pushing the shit out of that turbo and engine
A 2wd has a good advantage here assuming good suspension setup and well prepped track.
We’re in with my buddies 02 ccsb, his truck, my trans/converter combo with me driving. We got a crazy turbo setup that nobody’s done before. Wrapping up the turbo now. Caltracs and mickeys on all 4 corners. We should start testing here locally end of March.
It’s 1/8 mile, insta-green, spec turbo, OEM ECM controlled, any trans combo just no trans brake and NO nitrous.
We are going to turn some heads, no doubt.
Someone needs to start building them a beam breaker.....
I'm curious if there's anybody buying multiple turbos and dynoing them all looking for that turbo that one that gives them an extra 30hp.
I'm excited just to see what kind of shit people come up with to give them an advantage.
Yep. If you know you're under gunned your only chance is take a shot. Red lighting be dammed.So you can jump the light with a slower truck and win
