I need my head examined. 2002 GMC 2500 6.0 4x4 hoopdie.
036.6turbo
945
254
Drug home another orphan. Need to up my snowplow game. (and yes, if this is an upgrade, I know, I know) This thing has a Western Ultra mount. Basically, gave him for the truck, what the plow is worth. It's a crank no start. W/T with 86k showing on the odometer. He was asking $2100, I offered 1,600. (hoping he'd say no). Unfortunately, he bit on the offer. May just pull the plow and part it out, who knows. I'll get it running first, then do a better evaluation of its future. He says it has spark and fuel pressure, used to run then one day it didn't. We'll see what I find.
Figured I share my insanity with the group.
3,577
I think I saw that truck on FB Marketplace.
James, looks like she needs rockers and corners, same as most Michigan trucks.
03, theres a shop in the Carson City area that specializes in replacing those parts, if you want to look into it.
036.6turbo
945
254
What Tom said. If I choose to keep it, I can do those repairs. Definitely in my wheelhouse. PO actually had already bought everything for the drivers side. Floor pan / inner and outer rockers / and a cab corner.
I can source doors / bed and tailgate in correct colors for under two grand. Rust free. Fenders I found would need paint, but they can be done when I paint the rockers.
That flatbed has to go. SRW never looks right with a flatbed IMO.
Yes Tom, FB MP got me again.
Once I hear it run, I'll decide if I bought just a plow or a plow truck.
I am 75% sure the 86,000 miles showing are actual. But I guess someone could have swapped the cluster. Nothing in the ECM on this old of a truck.
036.6turbo
945
254
Got it loaded up and hauled home.
No small feat, with the plow still mounted.
Had to load it backwards.
Probably a sign of things to come.
Everything backasswards.
1,673
My AZ ass would be running scared from things like that.
The sad thing is, Guys like us don't need Sheetmetal here and we can not sell it for anything more than scrap. I have literly thrown perfectly clean doors in the trash because its not worth my time to take to the scrap yard. I had a hard time Giving an 06 Crew cab with doors away. I almost had to pay to scrap it.
036.6turbo
945
254
Welcome to the great white north. 😂
Sad but true. Keep two trucks around so one can sit, and the other get trashed by road salt.
6.0/4L80?
6.0 yes, so I am assuming 4l80e. It's too old for GM to be very descriptive on the build sheet.1770634921583.png
You out in AZ like James?
036.6turbo
945
254
Shit, it's a 4.10 axle! That's gonna suck on my 60 mile commute each day.
Snowplow prep package. Been a Michigan truck it's whole life, sold out of Golling in Lake Orion.
Decoded by https://decoderpo.com/
12C:
- TRIM COMBINATION CLOTH, GRAPHITE (C) (92)
12I:
- INTERIOR TRIM GRAPHITE
1SA:
- PACKAGE-OPTION 01
- SALES PACKAGE
1SZ:
- PACKAGE OPTION-
- PREFERRED EQUIPMENT SAVINGS
6GL:
- COMPONENT FRT LH COMPUTER SEL SUSP (6GL)
74U:
- EXTERIOR COLOR,PRIMARY,VICTORY RED
7GL:
- COMPONENT FRT RH COMPUTER SEL SUSP (7GL)
AE7:
- SEAT,FRT SPLIT,EASY ENTRY
B3P:
- SALES PROCESSING OPT BAILMENT COMMERCIAL
B71:
- ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BLACK)
- ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(COLOR)
- ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(COLOR)(USED WITH TROFEO SPORT COUPE WL3)
- MOLDING,ROOF,BODY COLOR
C60:
- AIR CONDITIONER,FRONT,MANUAL CONTROLS
C6W:
- GVWR, 6945 lbs. (3150 kg)
- GVW RATING(9200 LBS)
DE2:
- Mirrors, outside manual, Black
- MIRROR,OUTSIDE,LH & RH,DIRECT CONTROL,FOLDING,PAINTED
E63:
- Pickup box
- Durabed, pickup bed
- Pickup bed
- BODY EQUIPMENT,FLEETSIDE PICKUP BOX
F60:
- Heavy Duty Front Spring Package
- Heavy Duty Front Spring/Camper Package
- SPRING,HEAVY DUTY,FRONT
FE9:
- Emissions, Federal requirements
- FEDERAL EMISSION CERTIFICATION
FT2:
- ARM TORS BAR SPRING ADJ (FT2)
FT3:
- ARM TORS BAR SPRING ADJ (FT3)
FWI:
- PLANT CODE FORT WAYNE, IN GM T&B
G80:
- Differential, heavy-duty locking rear
- Differential, automatic locking rear
- Differential, limited slip
- Auto-locking rear differential
- AXLE,REAR,POSITRACTION,LIMITED SLIP
GT5:
- AXLE,REAR,4.10 RATIO
HVY:
- IDENTIFICATION 2 INCH BODY RAISE, H.D. MODEL
JH6:
- BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS
K47:
- Air filter, high-capacity
- Air cleaner, high-capacity
- Air filter, heavy-duty
- Air filterHigh-capacity
- AIR CLEANER HIGH CAPACITY
KC4:
- Cooling, external engine oil cooler
- COOLING SYSTEM,ENGINE OIL
KG8:
- Alternator, 130 amps
- GENERATOR 130 AMP
KNP:
- Cooling, auxiliary external transmission oil cooler
- Cooling, auxiliary transmission oil cooler
- Cooling, external transmission oil cooler
- COOLING SYSTEM,TRANSMISSION,HEAVY DUTY
LQ4:
- ENGINE GAS, 8 CYL, 6.0L, MFI
MT1:
- TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E)
NA4:
- EMISSION SYSTEM,ABOVE 8500 LB GVW
NF2:
- EMISSION SYSTEM,FEDERAL,TIER 1
NP2:
- TRANSFER CASE,MANUAL SHIFT CONTROL,TWO SPEED
NZZ:
- Skid Plates
- Skid Plate Package
- Skid Plate
- PACKAGE,OFF ROAD SKID PLATE,SPORT
PDP:
- Enhanced Driver Confidence Package
- Texas Edition Plus
- LPO, Exterior Convenience Package
- SLT Luxury Plus Package
- Design Package 3
- LPO, Edition 1 Accessory Package
QIW:
- TIRE ALL LT245/75R16/E BL R/PE ST TL OOR
- TIRE ALL LT245/75R16/E BW R/PE ST TL OOR 120Q
R9Z:
- CONTROL SALES ITEM NO.100
SLM:
- SALES PROCESSING STOCK ORDERS
TFE:
- SALES INCENTIVE COMMITMENT PLUS
TRW:
- Roof-mounted lamp, provisions
- Provision for cab roof-mounted lamp/beacon
UM7:
- RADIO,AM/FM STEREO,ETR,CLOCK
UQ5:
- Audio system feature, 4-speaker system
- SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED
UY7:
- Trailering provisions, trailering wire harness only
- TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS
V22:
- Grille, chrome
- Grille, darkened front
- GRILLE,RADIATOR(CHROME)
V43:
- BUMPER,REAR STEP(PAINTED)
V73:
- VEHICLE STATEMENT - US/CANADA
VG3:
- STRIP,FRONT BUMPER IMPACT
VXS:
- VEHICLE COMPLETE
VYU:
- Snow Plow Prep Package
- Snow Plow Prep/Camper Package
- PROVISIONS,SNOW PLOW
XGK:
- TIRE FRONT LT245/75R16/E BL R/PE ST OOR
YD3:
- AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD6:
- SPRING,REAR(BASE EQUIPMENT)
YGK:
- TIRE REAR LT245/75R16/E BL R/PE ST OOR
Z85:
- Suspension Package, Standard
- Suspension Package, Handling/Trailering, heavy-duty
- CHASSIS PACKAGE,INCREASED CAPACITY
Z88:
- GMC TRUCK
ZGK:
- TIRE SPARE LT245/75R16/E BL R/PE ST OOR(9591214)
ZY:
- Not found
036.6turbo
945
254
Last dealer visit was in 05 it had 36,600 miles on it then. It's showing 86,000 now. So, driven only 2,500 miles per year in the last 20 years? Not sure I buy it. But the brake lines are original, as is the exhaust. So, who knows?
3,577
Makes sense if bought to be used primarily as a plow truck/spare truck.
Yep, 4l80E option MT1. 4:10 rear was common gear for HD gas. Not like you cant find another 3:73 if you had to.
Interesting that it was an SLT truck, though. You usually dont see that on Regular cab trucks.
036.6turbo
945
254
Never thought about swapping in some Dmax axles, good point.
I didn't get it on the lift yet, but the frame appears to all be there? Cross tube on the trailer hitch has a rust hole, but it survived the winch pull, dragging it up on the trailer. And seeing as how the plow cage bottomed out on the pavement, it was a pretty good pull.
