Sealing will be the same. Yes there is the advantage of a higher CR, which will help with a larger cam. Does it really make that much of a difference? Probably not in a diesel, it's good practice to get the quench tight as possible, within reason and not pushing the limits. Lots of shops will just slap a set of C gaskets on a head job and call it good, 99% of guys would never know any different.
How many old school gassers had the pistons -.025 plus a composite .040 gasket? The last sbc I put together had the pistons down about 020, the old man said to just run a Felpro SD composite which is like 045". I said F that it's getting a .015 steel shim haha
