2007 LBZ into 2005 LLY
361ddm
Oct 30, 2025
dayton ohio
Installing a 2007 LBZ with 6 spd tran into 2005 LLY w 5 spd.
I have the compete 2007 donor truck. Need help adapting the 2007 eng / chasis wiring harness to the 2005 Cab wiring harness.
Any help?
Thanks !
Welcome
There are several threads on people doing this. I believe it's pretty much plug and play if you use the engine, harness, ECM, TCM, etc from the donor
3,930
829
Russ @ RPM Motorsports has posted some info about it, might even be able to contact him directly. I believe there were a couple connectors that needed a pin moved
Cougar281
1,980
406
St Louis, MO
Without going back and finding my posts (it's been 'a minute' - afaik, I was among the first handful to do the swap), the main points were need to replace the accelerator pedal and harness I believe, and move one or two things in one of the under fuse block connectors.
3,581
Lets see, heres one thread about the water pump difference, and pedal
3,581
Wiring write up:
See post #11 from Cougar in this thread about a wiring issue:
3,581
Basically, you're swapping everything under the hood from the LBZ truck to the LLY. Swap throttle pedal, cluster, shifter. Repin a couple wires.
