2011 LML Duramax – CP4 Grenaded, New Fuel System Installed, Rail Pressure Stuck at 31,000 PSI
hollywoodhd
Oct 15, 2025
#G0makediesel
Hey everyone,
I’m looking for some help with my 2011 LML Duramax 6.6L. I bought the truck not running — the CP4 pump had grenaded, and someone had already been tinkering with it.
After confirming the CP4 failure myself, I replaced the following components:
  • New CP4 pump
  • New fuel rails
  • New injectors (programmed correctly after installation)
  • New fuel filter housing and fuel filter
  • FASS lift pump (already installed on the truck)
  • New water separator and fuel pump filters
I was told the ECM might be bad, so I sent it to G7 Computers for repair. The truck is deleted, and they said they could repair the ECM without affecting the tune. They sent it back saying it was “repaired,” but didn’t give any real details about the issue.
Now that everything’s back together, the truck will start briefly with shot of ether but then dies. If I try to build fuel pressure manually, it might hit for a second and die again. Sometimes it just cranks but never fully starts.
Using my Snap-on Apollo 9 scanner, I’m seeing the following:
  • Actual rail pressure: locked at 31,000 PSI (never changes, even while cranking) or unplugged
  • Desired rail pressure: only goes up to about 1,200 PSI while cranking
When I unplug the fuel rail pressure sensor on the driver-side rail, the reading doesn’t change — it stays locked at 31,000 PSI. The sensor has three wires:
  • Red: 0 volts
  • Yellow: 5 volts
  • Brownish-gray: 0 volts
The truck also isn’t communicating with the Glow Plug Control Module (GPCM). I’m not sure if that’s related to the no-start issue, but I wanted to mention it just in case it matters.
At this point, the rail pressure reading is frozen at 31,000 PSI no matter what I do, and the truck won’t start but hits every now and then
Current Codes:​
P0641, P0532, P0193, P0192, P2294, U0106, P0340, C0561, U1511, B0775, B0780, B0785, B0790, B2725, P0677, P0675
Any advice or direction on what to check next would be greatly appreciated — especially if anyone’s dealt with a CP4 failure followed by multiple electrical and fuel pressure codes like this.
Thanks in advance!
3,149
Hey everyone,
  • New CP4 pump
  • New fuel rails
  • Red: 0 volts
  • Yellow: 5 volts
Current Codes:​
Thanks in advance!
I'm pretty sure that yellow wire is supposed to be the signal TO to the ecm to indicate the pressure. If you have 5 volts on it, that would make the ECM think it's at maximum pressure. Maybe a short. Time to thoroughly inspect the harness
hollywoodhd
Oct 15, 2025
#G0makediesel
Okay, I will check the harness next
Ron Nielson
930
234
Berryton, KS
Info attached
  • FPR Fuel Pressure Regulator_ Diagrams — 2011 Chevrolet Silverado 3500 4WD V8-6.6L DSL Turbo Se...pdf
hollywoodhd
Oct 15, 2025
#G0makediesel
This is the pressure switch in the firewall side of the driverside fuel rail
