Strange symptoms
Jimmary22
Sep 22, 2025
15
67
North Florida
Lately on cool mornings when I start the truck I have been experiencing some strange things. After starting I noticed on the gauge cluster brake light comes on, the indicator under the Park position is not lit and stays off no matter the position. Shifting into any position is not smooth but rather rough. If I attempt to drive the transmission will not shift to a higher gear and it seems to be stuck in either first or second. (High rpm and slow speed). After the truck warms up or if I start it later in the morning or afternoon it is fine. Any ideas
Ron Nielson
930
234
Berryton, KS
First check is to see what the fluid level is. The fact that the underline under the P indicator often says that the TCM or wiring has a problem.. Scan for aocdes with a tool that will read TCM codes. Not all readers will do that.
Jimmary22
Sep 22, 2025
15
67
North Florida
Thanks, I did check the brake fluid level and it is fine. I’m not sure if the scanner I have will scan for transmission codes.
Also check with a scan tool what the transmission temperature is if it seems colder than it actually is, you might have a bad sensor or harness
And the fluid Ron is referring too is not the brake but the transmission fluid
Jimmary22
Sep 22, 2025
15
67
North Florida
I will check the transmission fluid level but as far as the temperature goes, these symptoms are at initial start on a cool morning before anything has a chance to warm up. Once it does the symptoms go away. Was wondering about moisture intrusion somewhere since it is located in north central Florida and the humidity is high even on cool mornings.
Jimmary22
Sep 22, 2025
15
67
North Florida
Transmission fluid is fine. Later in the day and symptoms are gone.
Jimmary22
Sep 22, 2025
15
67
North Florida
Used a scan tool and U0101 came up. (Lost communication with TCM) which makes sense except these symptoms only occur when it’s cold. I have hung a light close to the TCM and the ECM and after about a half hour everything is fine.
Ron Nielson
930
234
Berryton, KS
A little more info for future needs
  • 2008 Ground Distribution.pdf
  • Grounds Locations — 2008 Chevrolet Silverado 2500 4WD V8-6.6L DSL Turbo Service Manual _ Opera...pdf
Jimmary22
Sep 22, 2025
15
67
North Florida
Try grounding the tcm case externally, might have a bad tcm grounding. Lmm is known for it.
Tried that this morning, same results. Whatever it is, it is ambient temperature related. This morning outside temperature was 50 degrees. By this afternoon when the temperature rises the symptoms will be gone.
8,236
Pull the tcm and leave it inside the house over night, then plug it in the next morning and see what it does.
Probably needs a tcm
