Hopefully someone can point me in the right direction. Have been dealing with the Allison in my lb7 either not going into reverse or going to 5th when I shift to drive and occasionally getting stuck in 5th or 1st. No codes but shift range inhibited on the dic when it won’t go into reverse. This has slowly progressed from an intermittent issue.
Fired up the parts cannon and put a new internal harness and nsbu in it which didn’t help. Chased all the wires visually and attempted to clean all the grounds. Wiring diagram shows ground zone 4 as the one im looking for which is passenger side back of block. I can’t seem to find it. Closest thing is battery cables to the starter solenoid. It shows that same ground T’ing off to the one on drivers side front of cyl head where the jump post is. Where is the one on the passenger side? Thanks for the help.
