I'm going to try to put a second gear start on my 06 but I want to be able to activate it in tow haul only. How would I go about doing that? Thank you ?
There are separate tables for T/H and 4low. Pick the one you use for pullingOk thank you ? and truck pulling, and if you set that up to do that just when you hit the t/h button it will work the same? Thank you
I want to say they are. But would have to look again to verify. Since I'm at work and can't look directly at the tunes, I can probably look at one of the calculators I made in Excel and see what I put in itAre the tables backwards in the 6 speed files too? Used to be that the 4LO and T/H modes were mislabeled. For 2nd or 3rd gear start tunes I was just making all modes except regular drive the same
Cal flash is fine. A full flash will reset your TAPs and you'll have to relearn it. Shoot me your email and I'll send you the file I set up for my truck. The TC lockup tables were modified as wellYea I would appreciate it and do you have to full flash when you do it? or can it only cal flash?
