Time for new bearings, again
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,563
89
LA
So I replaced bad hub bearings back in January of 2022 and only got 3 years and less than 40k miles. I believe i used SKF x-tracker hybrid. It's time to do it again, what are the best options for front hub bearings now?
Sent from my SM-S921U using Tapatalk
SKF, Timken, NTN, etc. all the ones you used to be able to rely on seem to be a hit or miss now. Quality control has gone downhill in bearings it seems. Might just use the same one or any of the "top" tier and see if you get a good one. Probably a 50/50 chance
countrycorey
Jan 30, 2010
1,563
89
LA
There was nothing else going on that affected the lifespan?
I have been running the 5 spoke denali 20s with adapters since may 2017 and i installed the current hubs in january 2022. I'm taking them off and going back to no spacers/adapters and boulder h2s with ~33s (trail grapplers most likely) this month.
