Engine swap holy moly , 06 LBZ into 05 LLY, no start
Ron Nielson
930
234
Berryton, KS
Lots of grounds available for fixing! Might check the primary devices for poser and grounds.
From another post today:
Disconnected the bats for 30m reconnected and it started..
Amazing how many times this gets the engine going. And it doesn't cost anything. disconnecting negative battery posts on both batteries will get the job done
  • 2003 Ground Zones.pdf
HDduramax
Diesel is all I need
Nov 19, 2024
40
Texas
So yeah I completely understand like I said I rewired some wiring harnesses and it cranks but it just won't start unless I put starter fluid spray in the manifold and a couple days ago it did start but now it just doesn't want to start a cranks but does it starts I did find a ground yesterday fix that one as well there's air stuck somewhere and I don't know what to do after priming the fuel it wants to crank just doesn't want to start there's got to be there somewhere trying to figure that out I appreciate all of y'all I'm trying to help me
HDduramax
Nov 19, 2024
40
Texas
Cool beans thank you for the ground diagram I'm on it right now
3,590
Need to go back over what you've done in detail bc you've forgotten something.
Did you use the entire LBZ underhood wiring harness? If not, what did you use?
Did you attach every ground wire from that harness to its proper spot, whether that be engine block or frame?
Have you checked all the fuses in the fuseblock as good, esp the ignition fuses? (No assuming)
Did you verify your crank and cam sensors are good and the signals are correct with a scanner?
Did you check FPR and CP3 cranking output with scanner?
HDduramax
Nov 19, 2024
40
Texas
I'm on it right now that's what I'm checking to make sure all my grounds are good make sure nothing is exposed or touching any kind of metal also I did replace the camshaft sensor the crankshaft sensor the high fuel pressure regulator sensor but I'm thinking it's the regulator it might be that but I'm still going to go at this I appreciate you
When you say it only starts with starting fluid, are you saying it continues to run or it only runs while starting fluid is in it?
If it does start with starting fluid then you have a fuel issue
HDduramax
Nov 19, 2024
40
Texas
No it wants to start but fails so I figured the pressure regulator or the fuel primer it's self later on getting new hoses for fuel line pressure primer along with fuel filter and checking all the grounds thanks for the input
HDduramax
Nov 19, 2024
40
Texas
We ordered a fuel pump primer our big issue found. While waiting for this item can I start my motor by bypassing this item but unplugging the return line with diesel to start it. If so is it the top or bottom return line. Feeling confident on doing this
3,931
829
I didn't read every post you made, but I would not bypass the fuel primer, you'll be bypassing the filter as well unless you have an auxiliary fuel filter / pump setup. I'm sure it wouldn't be the worst thing to bypass it for a bit, but there's zero filtration otherwise. The filter head / primer should have arrows on the inlet to indicate which way is in / out
HDduramax
Nov 19, 2024
40
Texas
Ahh gotcha I greatly appreciate you will do this and let's see. The reason I asked that question is cuz I had a customer yesterday that came to buy a crankshaft from me, and he did say if I just want to try to turn it on just to see if the engine works or everything's good besides that primer part to do that and I was just like I've never heard of such a thing so that's why I was asking but I greatly appreciate y'all being here for me and we'll see
HDduramax
Nov 19, 2024
40
Texas
Ok, it will throw a code as well. If you think it's a fuel issue, fix that first and continue on. I don't know how to answer that question.
I'll see. Actually since he was a customer of mine I think I shoot a text to him and clarify. Then we will go from there
