2wd chassis to 4wd
1,675
I was told when I tried to order them that they were never available separately as a Serviceable part.
Supposedly they are bonded in place.
My thought was to try and use a control arm bushing.
I think the hanger bushing like you are linking is too long.
1,675
Ok Mr. smarty pants here you go in metric measurements. Atleast the front part that goes through the frame.?
I think this is the correct differential to frame bracket 15999801 but I could be wrong....
3,589
I literally just randomly looked at that one, Brick. Its roughly 70mm long, not 66.
But that leads me to believe that there is one out there that could work. Just need to be able to accommodate a 14mm bolt.
3,149
I don't see why the part Tom linked too wouldn't work. As long as the diameter is correct. It could be chopped shorter if needed.
Is that 14mm bolt fixed into the bracket and not removable?
1,675
it's possible!
I looked on EBay and they say that's a 1500 bracket for the front differential. I don't have a 2500 unit here at the house that separate.
3,149
1,675
There you go. Still need a frame sleeve though
3,930
829
That's what I was told by the dealer when I did this back in 2016, couldn't order the bushing. I have an Energy bushing in mine, just went to the local machine shop and had them cut me a piece of tube that was a hair smaller than the bushing OD. I do not remember what schedule pipe it was
