Let’s be honest, do you really think an S300 will last on The Limo ?That’s awesome, thanks guys.
Hey, an s300 will survive high shaft speeds better than an s400. Smaller shaft and bearings = surface speedLet’s be honest, do you really think an S300 will last on The Limo ?
It would definitely be better than the IHI, I just see it being turned up more once it’s on ?I think a gated S300 in place of the current ihi would work well for James. Throw a shaft speed gauge on it and see what happens.
If only the Duramax Tuner Stealth 67 that was essentially an S467 shoe-horned into an IHI housing didn't suck![]()
From running the S300 (362/68)on a 8.3L Cummins, there isn't much adjustment to lower the boost point much below 40psi. You'll have to make a longer female part to lower spring tension to open sooner.People really sleep on the small turbine S300s. They're not intended to make gobs of power but their response is insane. That's why I'm hoping the gated housing allows me to spray it and not send the compressor wheel into the intercooler haha.
Let’s be honest, do you really think an S300 will last on The Limo![]()
. Hell I’ve considered going down on the big turbo size but talked myself out of that.I plan on running a spring gate OR a Turbosmart actuator that I can change spring pressures on.From running the S300 (362/68)on a 8.3L Cummins, there isn't much adjustment to lower the boost point much below 40psi. You'll have to make a longer female part to lower spring tension to open sooner.
I was referring to the spring/boost gate that comes with the gated housingI plan on running a spring gate OR a Turbosmart actuator that I can change spring pressures on.
I know. I do not plan on using that actuator. Stainless Diesel makes a spring-loaded actuator and Turbosmart makes an actuator that you can easily swap springs on. They both work with the Borg gated housing.I was referring to the spring/boost gate that comes with the gated housing
That's good to know, might get that and put a 362/68 back on vs the 362/73, as the engine starts to choke out about 10-15psiI know. I do not plan on using that actuator. Stainless Diesel makes a spring-loaded actuator and Turbosmart makes an actuator that you can easily swap springs on. They both work with the Borg gated housing.
