: Recall # N242454440 MOMENTARY REAR WHEEL LOCK-UP
BradN
Jul 29, 2024
Los Alamos, NM
Anyone else experiencing this?
I bought my 2020 2500HD a few weeks ago. First trip pulling a light (3500lb) camper. Cruise set to 65 going up an incline.
BANG!!! rear axle locks up momentarily, nearly putting my wife and I into the windshield.
WTF!!!
Couple miles later, same thing, this time I get kicked 2' across the center line. Wife is freaking out. We pull over, turn around and baby it back home.
Take it to a shop and they have no clue. No warning lights. Nothing appears wrong.
Two days later I get a carfax email about this:
Recall# N242454440
So now I get to wait for GM to figure out a fix for my, not even registered yet, $40K death trap.
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
Somewhere On The Ohio
www.marinemods.us
What Should Customers Do?
  • For Current Owners: While there is no immediate fix for the issue, current owners should remain aware of their vehicle’s behavior, especially if they experience harsh shifting.
Well shifting you 2 lanes while towing a camper certainly qualifies as Harsh in my book..
Thanks for the alert.
BradN
Jul 29, 2024
Los Alamos, NM
Yeah, I'd say we're pretty damn aware of our vehicle's behavior. How about GM getting aware of fixing it.
Cougar281
1,962
384
St Louis, MO
So what's different about the transmission in the half tons vs the 10 speed found in other vehicles like my CT6 and the CT5 & CT4? I believe all of the 10L's are essentially the same. What did they change to create this problem, or is it likely to affect ALL vehicles with a 10 speed?
BradN
Jul 29, 2024
Los Alamos, NM
I fully concur with your assessment. There's a reason valve spools never have o-rings. Plus the fact that I'm sure it's the housing that's worn, not the spools. That means the spool to body clearance is bad which puts o-rings at further risk.
I assume (OK, I hope) the GM fix involves replacing that upper valve body section. I can't imagine anything else will work.
3,886
801
Sonnax makes a lot of oversized valves and reamers for valve bodies but not really anything for the 10L1000 other than TCC parts. I imagine if issues persist and GM can't remedy it or keep up with replacement valve bodies then Sonnax will more than likely start.
3,419
Question: Do you guys think that fluid is leaking around the valves, causing some sort of transmission tie-up?
This is the kind of problem that Mike always used to be able to solve. Dang it.
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
www.marinemods.us
My buddy left town for the weekend, so this seal reveal party is back under the bench until I return. :cry:
I'm guessing it engaging two gears/clutches like a trans brake. Which if so, would be very bad.
Or it's detecting a slip and going into a limp mode, which might be 2nd gear. Which at 80, would feel like you locked up..
3,419
Is the same transmission used in other GM cars, not just trucks? If so, are those vehicles having the same issues? If not, whats different about the truck trans vs the car trans that could be contributing? Just me and my uninformed ideas again....
3,886
801
Cross leaks in the valve body can definitely cause serious damage, but without knowing exactly where the wear areas and which valves apply what I'm just guessing. I've never seen it cause the rear tires suddenly lock up, but there's been plenty of valve body complaints on the 10L
Mikey52
170
According to video, the wheels didn't lock up. Just that at high speed, it shifts into 2nd gear. It would appear that they locked up, but 65+ mph with torque converter locked, I imagine a lot of screeching would take place.
