2020 Oil Cooler Retrofit Kits (01-19)
1,862
I have created a prepackaged kit for 01-19 trucks to install the 20+ GM oil cooler. I am going to be retailing this kit at $450 to your door anywhere in the continental US. This kit will include every gasket, seal, component, 10.9 flanged hardware, thread locker, and o-ring lube to do the job.
Let me know if I can help get a kit coming to anyone!
This will include:
1) GM 2020+ oil cooler
2) GM 2020+ elbow
3) GM cooler to elbow seal
4) GM elbow to rear engine cover seal
5) GM water pump outlet to tube seal
6) GM water pump tube to oil cooler o-ring (pricey bastard)
7) AmsOil EAO17 oil filter (full synthetic media)
8) 2x M8-1.25x120mm bolts (cooler>block)
9) 3x M8-1.25x40mm bolts (cooler>block)
10) 5x M8-1.25x25mm bolts (3x for elbow>cooler and 2x for elbow>rear cover)
pl_silverado
189
161
Never mind. Scratch that. My engine builder already has one, and is further along than I expected.
1,862
I didn't see this, my appologies!
Thank you to all who preordered, I've sent all 10 out and have ordered another 2 to keep in stock on the shelf!
O-ring lube and thread locker did not come in so single use packets were not included this go around. I'm working with a few companies to order "counter packs" (AKA what you see at the parts store counter) to make everyone's life easier.
1,862
Got my kit today, thank you. Now I need to get the engine together.
Glad it made it there safe and sound! The reason I cut open the oil cooler box itself was to verify the cooler did not get damaged. I've had far to many show up damaged. As of late, GM has gotten it together on these not being thrown off the back of a moving truck haha.
