LLY Truck Crank Signal Issue - P0335
Shane H
Jul 23, 2024
Alberta, Canada
Ran the truck in my sig dry about 100m away from the fuel station. Was able to get it pushed close enough. Got it to run for 5 minutes but still had to haul it home that night.
Bled the return lines, bled the banjo fitting on the top side of the FICM. Bled the schrader valve by the alternator. Even bled a few of the accessible injectors. and both rails. Truck has a FASS 165. Filters are primed. Truck will NOT fire on diesel. I pinched the return line. Disconnected the FCA. Truck throws an intermittent P0335.
Edit* After much messing around, determined I did not run truck out of fuel. Ended up being a crank signal/rpm signal issue.
kidturbo
Piston Tester
Jul 21, 2010
2,810
1,805
Somewhere On The Ohio
www.marinemods.us
Sounds like it might have stuck the FP regulator. The P0335 is weird because it won't fire without the cam signal, but that's no ways related to running out of fuel. Need to verify you have decent fuel pressure on the rail for it to fire, and make sure you are getting RPM signal. Last look at that cam sensor missed pulse data and see if maybe it is a bad connection.
Shane H
Jul 23, 2024
Alberta, Canada
I'll verify everything else next week when I get time to look at it again. Fuel Rail Pressure climbs to 27k psi as I'm cranking the starter and dwindles back down to nothing when leaving the key on accessory. Desired Fuel Pressure is asking for 5800-6k at start up. This is the same with the FCA plugged in and unplugged.
Shane H
Jul 23, 2024
Alberta, Canada
If it's making good cranking pressure, then most certainly it's electrical.
Yep. Loaded up the parts cannon. Had the batteries warrantied as they were only generating half the CCA and threw a crank position sensor at it. Still P0335. And Ive verified that I dont have RPM signal.
993
You need to be looking into that CKP code. Here's the diagnostics for it if you need some guidance on figuring it out.
  • P0335.pdf
Ron Nielson
930
234
Berryton, KS
Fuel Rail Pressure climbs to 27k psi as I'm cranking the starter ...... This is the same with the FCA plugged in and unplugged.
Yup, anytime the FPR is not powered for any reason, you get full fuel pressure. There is definitely a problem in the FPR or wiring somewhere.
