Excellent information. Thank you so much for commenting. I have been logging but using your method makes way more sense.
I have some questions on pilot timing. Does advancing the pilot injection help or hinder mileage? Seems like it would hinder mileage but I’m just trying to theorize in my head.
Would a bigger pilot injection smooth out the burn and also add a touch more power?
Thanks for your time
I'll preface this with the comment that my situation with tweaking the pilot timing is a bit unique. I replaced my stock injectors with 45% over SAC-style injectors, which are both larger and have a different style nozzle from the stock LB7 ones, so a pretty drastic total change from stock. I never messed with the pilot until after doing this, so I can't really speak to how accurate / optimized the factory values are (for my truck, or other generations).
I have also realized that pilot parameters are a bit of black magic. I have a fairly deep engineering background and consider myself reasonably adept at understanding the theory behind most of this tuning stuff, but I absolutely do not have a full grasp on exactly how the pilot timing and quantity
should work.
The one thing I have determined fairly conclusively is that it's the
time that matters, not crank-angle-degrees (CAD). Again, I'm not familiar with the LBZ and newer stuff, but if you convert the LB7 and LLY timing tables from degrees to microseconds, it's very obvious what GM was doing. The time is pretty consistent (exact in the LLY's case) across the rpm ranges, with only small changes at low rpm and load.
Before I put the 45% SAC injectors in, I regularly got 18-19 mpg cruising at 70, sometimes as high as 20 in perfect conditions. After I put them in, I tweaked the timing and fuel pressures (as per the datalogging procedures I mentioned in my last post), but I was only getting 16-17 mpg. Even with near perfect conditions, it was only maybe 17.5, so I knew something was still off (or the injectors just sucked, which seemed unlikely).
I saw several posts online recommending switching to the LLY pilot timing maps, which is logical since the stock LLY injectors are also SAC nozzles. It has the pilot about 100-300 us further advanced / separated from the main at cruising. I did this and instantly picked up a solid 1.5+ mpg. The last 3 tanks have all been over 19 mpg.
I wrote a DSP5 program with the pilot timing at -400, -200, 0, +200, +400 microseconds of pilot timing, with '0' being the stock LLY map. I have not yet had the time to datalog like I'd mentioned earlier, but I've done a couple less-scientific tests.
- The -200 (close to stock LB7 timing) is very slightly quieter, but with moderate increases in main mm3 (which matches my fuel mileage observations from the LB7 to LLY pilot timing).
- The -400 is slightly quieter still, but with a substantial increase in mm3. It was significant enough that I can actually feel the truck surge forward a bit when changing from -400 to 0.
- The +200 sounds about the same, and shows a very slight decrease in main mm3.
- The +400 is somewhat louder / more rattle-y, and shows a tiny bit less mm3.
I haven't been scientific enough to determine if there's actually a mileage gain at +200 to +400, but if there is, it's small enough that I'll probably choose the quieter tune over a fraction of a mpg gain. Definitely more logging that I need to do.
I also still need to play with pilot quantity. Unfortunately, this isn't a DSP5 parameter with the LB7. I can still log the mileage with single tunes, but it's MUCH easier to judge noise, driveability, smoke, etc. with the instant switch. It IS a DSP2 parameter, I just need to get a switch for it.
It's logical that I'd need to pull some pulse / quantity since I have bigger injectors, but I pulled 15% on an experimental tune a while back, and both part-throttle and WOT smoke got noticeably worse. Opposite what I expected. I've also read some pretty convincing posts on the Cummins forums of less noise, smoke, and fuel consumption with a larger pilot. Again, opposite what I'd think, so I still have some testing to do there.
The bottom line of all this is that it is definitely possible to see increases via pilot tuning, depending on your setup. Then again, it's definitely possible that you won't.
Hence the 'black magic' comment. : )
