Junk Yard ECM LLY Tune Help
thunder57
Jul 9, 2014
9
Purchased an ECM from a yard, truck had a dsp5 switch.
Seeing if anyone could take a guess on what tunes are on it.
I'll upload the pulled file and script from the ECM.
Thanks
  • JunkYard LLY DSP5.zip
  • LLY DSP5 Unknown.txt
1,786
from the looks of it, 0 is stock, 1 through 3 look ok on power. 4 looks hot and timing is too high. #2 is about as much as I would do for a stock transmission
also, TLIQ seems way off for good healthy shifts on all 1-4
my $0.02
thunder57
Jul 9, 2014
9
my $0.02
Appreciate the input!
3,346
375
They modified the timing B table in the base file but not A or C? Not sure why the rev limiter is 4200 when none of them fuel that high. Timing tables kind of look like 30mm3 and up was just C&P from another tune, timing on dsp4 is probably higher than it needs to be but won't hurt anything. 2100us on the dsp4 is beyond what I'd recommend for a stock trans as well, but probably what most would consider a max "stock trans" tune which usually will limp in 5th if drove hard
Reactions: 2004LB7
