coolant fan relay location
Old Guy With Issues
Jan 29, 2024
Washington State
OK, I have a 2007 gmc Sierra classic 2500hd with the duramax LBZ. My cooling fan runs full blast all the time. I did some research and found a couple of possibilities. The first thing I want to do is replace the coolant fan relay. I have the part already. How ever, I am unable to get any specific information on where this relay is located. Any help with this issue will be greatly appreciated.
4,850
1,902
If the truck is struggling to maintain temperature I would at minimum check the fan clutch for resistance and possibly replace it with a Kennedy or Hayden unit as well as a new set of GM thermostats. From what I've seen the GM thermostats seem to be the most stable and run similar average temps (2-3f warmer) to my low temp Mishimoto thermostat set over the course of the same drive in almost identical weather conditions.
Old Guy With Issues
Jan 29, 2024
Washington State
What coolant temp is the truck reaching?
OK, at 50 degrees outside, after starting and warming up for 30 min. temp reads 180 degrees. When I hit the freeway, the temp comes up to operating temp. right below 210 degrees. This is driving on freeway for approx. 15 minutes. When I get off the freeway, temp. lowers back down to a little above180 degrees. If temp outside is above 55 degrees, when warming up, the temp. gets to 180 degrees. When I start driving in town, temp comes up to 210 degrees. When I come to a stop, the temp. stays at 210 degrees.
How do you know it's running full blast? Does it sound like it's roaring. Typically when they fully engage you will definitely hear the difference
