I am starting another Dmax/Humvee swap, I picked up a 07 LBZ salvage truck with 205K and the drivetrain looks OK.
I am pretty strong in the electrical/electronics field albeit not too much with the GM stuff, but I plan on building my own harness as I plan on using the factory cluster and possibly some other "modules"
I am sure I will have plenty of questions but the first is why am I seeing references to a PCM and a ECM in the schematics, are there two different modules or are they contained in the same housing??
I see class 2 data which appears to all be one wire and simply parallel, the high speed data appears to be both parallel and series I ran into this with my LMM conversion when I had high speed com. issue due to the fact I was not using a glow plug controller.
