If you were to build an LML....
Dm23
449
171
Socal
Just cause I’m curious. If you were to build a 750-800hp DD LML. How would you build it? What internals/externals, brands. What kind of piston, crank, heads etc and why? Single turbo, compound setup? Just want to see what everyone’s opinions are.
1,514
Lml crank, head studs, twins 364/480 comparable size, 60 over injectors,
Maybe 40s and crank rail pressure up to increase volume via pressure which would increase atomization..
valve spring upgrades, with single CP3 IDK if a 10mm will but 12mm should, dual stock definitely will.
Billet rods
Cam isn't needed but would help, definitely a case for a alternate fire camshaft. Though I'm not personally sold on it
Keyed crank/cam minimum
Main studs, billet caps aren't needed but definitely money well spent.
Mahle performance pistons, ovals or de-lipped, diamond pistons is another option.
OEM Head work would definitely help.
I'd run 18:1 CR for daily use, easier starting and crisper throttle response. Definitely thought about building a 19:1 engine.
At minimum exhaust up pipes, manifolds would be a good addition though smaller versions vs larger pipes as you'll spend more time at part throttle than WOT
Pending RPM you plan on spinning aftermarket harmonic dampener.
Drill out fuel rail ports/fittings for increase volume.
Most likely will need billet hard parts in the transmission at that level.
Just a rough non polished thought process from me..
Dm23
449
171
Socal
Thanks for the feed back. I haven’t seen or heard of many people on this site going into detail in regards to this platform. I’m thinking long term for a really fun DD. I really want to keep and add to what I have already got. With the 65mm/cp3 etc. looking at 100% SS overs currently.
4,850
1,902
If I wanted a 750-800whp LML to do everything it would be as follows:
****Engine****
1) SoCal rods
2) Callies compstar crank
3) Any cam that doesn't require reliefs
4) Mahle Motorsport or Fingers Ovals (cast) (16.8:1 area)
5) ARP everywhere (625 head studs)
6) BD/Goerend/DHD style flexplate
7) 2020+ oil cooler
8) DHD pinned/shimmed oil pump
9) Mahle performance main/rod bearings (H or HX depending on clearance), Mahle standard cam/thrust bearings
10) Fluidampr
11) Good conical valve springs (Manton/XDP, SoCal, Comp, Fleece etc. Skip dual springs)
12) Good pushrods (Manton/XDP, SoCal, Fleece, II, Merchant, Trend etc)
****Fuel****
1) Dynomite or Exergy 100% injectors
2) 12mm CP3 of your choice
3) AirDog II-5G 220gph
****Air****
1) 63.5 vgt/480 or 65 vgt/480
2) Intercooler of your choice
****Built Trans****
1) Billet input
2) Billet C2 hub
3) Goerend R converter
4) Mishimoto cooler
Dm23
449
171
Socal
Thank you, I appreciate your help. These types of comments are exactly what I was looking for. I'm sure it will help myself and anybody down the road who come across this thread.
CDmax16
68
17
57
NNV
****Engine****
1) SoCal rods
7) 2020+ oil cooler
10) Fluidampr
****Fuel****
****Air****
****Built Trans****
1) Billet input
2) Billet C2 hub
4) Mishimoto cooler
Would this be the same for a 600-650 hp build?
ikeG
Oughta Know Better
Apr 19, 2011
2,557
192
Western PA
www.facebook.com
Callies compustar cranks can be a cunt to get to seal up on rear mains so I personally uses the jv8 on the inside and outside of that seal before I press it in otherwise it'll be out again to get a new one fought 4 straight motor builds that way.
What rear seal installer do you use? If you use one that does not have a relief in it for the dowel, you can run into problems like you mentioned
1,514
What I use.
And driver handle
ikeG
Oughta Know Better
Apr 19, 2011
2,557
192
Western PA
www.facebook.com
What I use.
And driver handle
That's what I was getting at, this style has no rear dowel relief, so depending on the length the dowel was cut to(callies do not come with dowels) it can cause rear mains to be installed crooked.
1,514
Nope, it's deep enough to not hit the dowel. Eric was smarter then that when building them.
I have seen ones that are too shallow and do exactly what you say
