2002 Duramax trans problems. Hopefully electrical
Alaskasurf
Nov 8, 2023
Fairbanks Ak
I just bought a 2002. I knew it had some electrical issues. The gear indicator on the cluster comes and goes. Mostly gone and the trans shifts hard and has a delay on start. I thought it was torque converter drainback at first but pulled codes and seems to be electrical maybe. It has a leak coming out of the gasket between the trans and converter also.
So today I started trying to fix it. First I took the batteries loose and disconnected the TCM cleaned and greased the connections. I think they looked fine. Connected TCM and batteries back, Speedo went to 100mph pegged and stays now ?. Apparently I just made it worse. I’ve glanced to see all transmission plugs are connected but haven’t taken any off yet to inspect. Then I had to go to work so that’s all I’ve done so far.
Truck has no problems starting 4WD works and switches just the error codes and the hard shifting and delayed start like it’s hunting for the right gear. See codes IMG_2954.jpeg
Any help or ideas would be greatly appreciated!
Alaskasurf
Nov 8, 2023
Fairbanks Ak
I took off that pass though connection. The one that talks to the solenoids on the valve body. It was full of transmission fluid at the connection. That could be part of the problem I’m guessing. Also the leak appears to be coming from the top of the extension housing. Probably a crack I can’t see. I need to rep that as well. I’m a little confused on diagrams. Is the output shaft seal on the transmission side of the locking busing or the extension side?
1,863
If there is fluid in the passthrough connector it's time to replace the harness. That can and certainly has caused your codes on other vehicles.
There is no output shaft seal on a 4x4 Allison, it is sealed when the transfer case is installed. The transfer case has an input seal to stop fluid from the trans making it's way into the transfer case. There are 2 gaskets between the bell housing and main case (each side of the steel plate the stator support bolts to) as well as a gasket between the main case and extension housing.
Check your vent, it is located on the top of the transmission at the rear of the main case. It looks kind of like a mushroom. I've seen fluid come from that location when overfull or when they get very hot.
