I've had my motor built for about 5 years now, and I have an old Trent Nell / EPR turbo kit. It's a S371 with a clipped 74mm turbine. It has made 700+ HP but I mostly run it on a 660 HP tune to try and extend the life of the turbo, with limited success.
I've been toying with the idea of compounds since I built this motor, and am thinking it's about time to pull the trigger.
There's a local shop (Big Twin Diesel) that is recommending a Garrett GTX 4094 (68mm) over a 4718 (88mm). I don't know much about the Garrett stuff, and am curious if anyone has run a setup like this, how did you like it?
Motor setup: SAC75 injectors, 12mm CP3, Carrillo rods, Mahle race cast pistons, Comp Cams CCA-132-502-12.
Currently it won't build any boost below 2000 RPM, but my converter and shift strategy is setup so that works fine, even towing. I'd imagine compounds would do a bit better down low, but what I'm really hoping is to clean up smoke at WOT and get some better reliability out of the turbo(s).
So what do y'all think, will I be happy moving to Garrett ball bearing compound turbos?
