2002 LB7 powerloss new guy here
ryanford
Jul 20, 2023
wyoming
cp3 is fine replaced injectors fuel air filters airflow sensors truck runs will not go over 2200 rpm falls on its face i can get about 60mph out of it if i take my foot offf and let it shift? $7K in and none of the dumbasses around here can fix it i have a fass lift pump in a box but i dont think is going to get it. cp3 when tested is making 135 145 while power braking as soon as the truck is moving it falls off ? NO CODES AT ALL!
P.S, GOODRUNNING STRONGTRUCK I LIKE IT VERY MUCH.
3,058
Welcome
Also, double check you are not getting air in the fuel to the CP3 with a clear hose. If all is good do a return rate check on the injectors, cp3 and pressure relief
ryanford
Jul 20, 2023
wyoming
Welcome
yes starting to think fuel pressure valve
not sure had 2 master mech. put high dollar snap on puters to it no codes again mystery
3,421
Moved to LB7 section.
Where did you buy the injectors from? Not "top notch".
If you have a log of the CP3 pressures when the issue is happening, post it.
8,050
Removing my help after reading your comments. I see why the master techs were no help to you.
