Injector Hold Downs?
You can't, at least with the factory hold down. Has a bevel. I believe the Socal piece is the same way
Wonder if something like this would fit
8,237
Pretty sure the stock bolts and arp nuts don’t have a dish to them to match the recess.
3,590
So you could use those bolts on an LB7, right? We'd just have to find a solution to the LLY-up. Will search some more.
3,930
829
At that rate, even if the radius wasn't exact it wouldn't matter too much, as the friction surface would be on the washer not the hold down
