Best engine mounts?
turbovan
Too many toys!!!
Mar 4, 2018
155
25
Abbotsford, BC, Canada.
Mine are original and sagged and at 480K, my friend who drives like an idiot has torn 2 sets of GM mounts-the rubber seperated from the metal bracket.
I drive sanely, no burnouts and tow. Will I be ok with the GM mounts or any other suggestions. I've seen some of the HD mounts and yeah, I like my teeth not rattling.
TIA.
3,931
830
If you aren't loading up the engine doing 4wd launches a new stock one will be fine. Not sure if the genuine GM are any better or worse than aftermarket ones. When my drivers side ripped apart I just Por patched it back together, drilled and bolted it
8,237
From stock hp to well over a 1000hp, you can’t beat a bolted stock mount. Adds 0 vibrations to the chassis beyond what any stock mount would add and it’s cheap.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,768
545
P.N.W
This is what I'm doing with my motor when it's done.
Sent from my SM-S906U using Tapatalk
8,237
My friend tore both, lol. He can break stuff we only dream off.
same on my old truck but a torn driverside will eventually take out the pass side. also, high load reversing can take the pass side out as well.
i bolted the driver and left the pass side factory when i replaced them.
