4,846
1,894
Mine usually is too although I have to be careful as occasionally, I have seen things be higher than what I can get them online for. Not often but it does happen on certain things.
Might not be a bad Idea for you to do the kits. Just don't use the cheap looking bolts that banks shows in there's
I'm going to come in somewhere around $450 shipped in the lower 48. Thats everything in Josh's list (including filter).
not bad. 100 cheaper than banks with better customer service, better bolts, shipping included, etc
hay Tom, what about relevant information such as in post 1190? can we copy that over to the sticky? like a condensed thread or information center?
I know there is a few more such as BTU calculations for those trying to find a radiator, or remote oil filter adapters, temp sensors locations or even using the fuel temp sensor to monitor the oil temp, etc. lots of good info that we would have to sort through and copy over
KEVINL
1,431
Phoenix, AZ
I was thinking of going with a 2017-2019 cooler since it fits easier and uses the same filter not the the smaller 2020+ oil filter
my camper weighs about 9,000 loaded
8,235
considering the benefits, our temps out here and you having twins, id rrrreeeeaaaalllllyyyy consider the 2020+ cooler.
1,673
i think so but i dont remember. his being a re-power might be an issue but i really doubt it.
You posted the pictures in here, but they won't seem to load for me right now.
Took me a while to find the info. We should make a mini sticky with only the Tech info, Part numbers, and pictures of what works and what needs to be done.
Getting ready to do a repower my self so I was considering this while the power train is out and I reseal everything.
8,235
f-in tapatalk for ya. ill re-upload them and host to the site.
8,235
thats already been done by Josh (see link). i did add some links about the tweaks i had to do as well
1,673
Awesome!!! Now that's customer service right there!!! (y)
Thank you for adding the pictures back and the Updates with the technical info to the sticky!!!
KyleC4
470
Bay Area
Additional info that could be used. GM just came out and informed us that the PF63 is now the recommended oil filter for the 2020+ L5P engines. PF26 still can be used. The reason for the change is they briefly said the PF63, though narrower, is taller pleats and has more volumetric efficiency as well as better cold flow capabilities.
8,235
good to know, both for my truck and to add in there.
DRTYIVIASSACRE
Sep 23, 2025
23
South Carolina
Just to clarify for those following this thread that don't already know. The coolant pipe on the LMM that taps off the oil cooler adapter to the rear engine cover is the supply to the egr and then to the heater core. Not the return. Yes it can and should be re-routed like other generations, especially for those who no longer have an EGR and live in cold climates who value their heat.
This is my problem I am dealing with except I cannot get the pipe out it hits on my manifolds
