04 NSBU wiring diagram
Jsle131
Jan 17, 2022
23
Does anyone have a wiring diagram for a 04 LB7? I've tried Google and searching this forum with no luck. In my truck I have the following wires going to the 7 pin connector on the NSBU.
1. Orange/Black.
2. Pink maybe 16 gauge.
3. Pink maybe 18-20 gauge.
4. Dark Green.
5. Light Green.
6. Black/white.
7. Yellow.
dndj
Boost!
Apr 13, 2019
302
Oregon
This is from my '03, 04 should be same. Sorry, diagram above only had connector C1, I think you're looking for C2. Pinout below. The circuits on C2 appear to be scattered throughout various sections of the manual so let me know if there's a specific circuit you're interested in and I can try and find it.
Jsle131
Jan 17, 2022
23
Thanks for the diagrams. I think 04 is different. Wire colors are all different.
Ron Nielson
926
231
Berryton, KS
Attached is from GMUPFITTER for an LB7 (bottom left corner). It is common for wire colors not to match exactly.
  • NSBU LB7.pdf
dndj
Boost!
Apr 13, 2019
302
Oregon
Yup. Same wiring shown in post #2. C1(J1) is 4 position connector, C2(J2) is 7 position connector, and both carry NSBU circuits (also called Park/Neutral Position Switch in the GM manual).
Jsle131
Jan 17, 2022
23
Using the voltmeter I got the following with the key on.
Orn/blk 10v with truck in P.
2 pink wires 12v all the time.
Yellow wire 12v with truck in N.
Lt grn and drk grn no power.
Blk/wht is ground.
Going off of the functions list, does the following make sense?
A.orn/blk park/neutral signal.
B.lt grn park/neutral position switch signal.
C.pnk ignition voltage.
D.blk/wht ground.
E.pnk starter relay coil
F.drkgrn backup lamp supply voltage? No power to this wire while truck is in R.
G.yel neutral safety switch.
03CATEYELB7
Jun 26, 2022
Blk/wht is ground.
D.blk/wht ground.
Did you ever figure out if this was right?
Lb7 2003
Nov 2, 2025
Oregon
1. Orange/Black.
4. Dark Green.
5. Light Green.
6. Black/white.
7. Yellow.
IMG_0237.jpegIMG_0236.jpeghey all I’m having battery drain issue after taking my truck to a shop for transmission replacement they installed these and it’s killing my battery. Any help as to what colors go where would be best 2003 LB7 4x4 Allison 1000
