03' GMC SoCal stroker
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Are you worried about fuel volume at all with 3/8" vs the typical 1/2" line or is the image you for the brand? Looking on Amazon they do make a 10an to 2x 8an. Has me thinking about re-plumbing my fuel supply and returns now....... I know the inlet on the pump is obviously smaller than that but I'm wondering if the fuel volume directly at the inlet may help.
Not really, being a street truck still I didn’t want a bunch of lines running all over. If it was a competition only truck I would have done it different.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Brad Sankey for K&D service’s hooked me up with a pair Kryptonite upper control arms.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Also upgraded my tranny cooler with one from XDP.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Also had to replace my radiator because of a leak. I ended up buying a all aluminum from G-Plus. It looks identical to Mishimoto. Quality seems good, I guess we will see. It was under $200.
4,850
1,902
Also had to replace my radiator because of a leak. I ended up buying a all aluminum from G-Boost. It looks identical to Mishimoto. Quality seems good, I guess we will see. It was under $200
Glad to get you fixed up on those arms! I'm curious to see how that radiator does, never heard of them before.
8,238
did you check for electrolysis? my truck had a decent amount till i found my ground issue with my sub amp.
curious how it holds up too. Ron Davis was telling me how much the mishimotos were flexing in the trucks, causing them to crack. Which is interesting because thats why my ron davis cracked lol. he atleast added more structure to stop it though on the new one.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
No I didn’t, I think old radiator failed because of the heat and pressure when the water pump failed. The seal was leaking between plastic end tank and aluminum core.
993
I have a mishimoto radiator sitting in the scrap pile because it started leaking. We replaced it with a stock radiator from GM.
8,238
Interestingly enough, my stock radiator made it 15 years and it was replaced just for more additional cooling. Never did check electrolysis on it. The Ron Davis I did and was showing 2v through the damn thing while running. Found the amp ground was crap and the body to frame ground was undersized for the rest of the aftermarket crap I put in. Changed those and dropped to .1v while running.
The two weren’t related to my failure but figured it’s worth looking at on all aluminum rads
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Thanks guys! Trucks all back together and took it for a little rip the other day.
Here’s a list of some changes I made over the winter.
- New Edelbrock heads.
- Wagler billet water pump.
- HSP billet exhaust manifolds
- Replaced Kennedy pumps with Fass 260 pump.
- Replaced S491/96 with S491/102.
- Replaced .90a/r housing on S472/87 with a 1.0a/r housing.
- Replaced 150 injectors with 250’s.
- Replaced 3.73 gears with 4.56’s.
- Replaced 4” exhaust with muffler to 5” straight pipe exhaust.
4,850
1,902
How are you liking it thus far after the changes?
RMJ_LB7
200
13
29
California
I like your choice of wheels!!
