Below is a new Utube on towing with the new 2020 Silverado 1500 eco diesel:
https://www.youtube.com/watch?v=mdSzqhfxwwU
Rob created a new subforum in Hard Parts for the LM2 3.0, for when the tech questions start coming in about this engine....
https://www.duramaxdiesels.com/forum/forumdisplay.php?f=186
220 coolant temp when it’s 21* out.![]()
31 but it isn't that much of a difference. I've read that it runs pretty hot to keep emissions happy though.
That's correct, it does run hot due to emissions and a bunch of high tech stuff in it. Also has aluminium block with the iron cylinder inserts.
And a belt driven oil pump that requires replacement at 150k miles which requires trans removal to do. Was watching a vid on it the other day and this blew me away that they're using a wet belt to run the oil pump when everything else is chains.
That’s not terrible but I’d be pushing the max on payload when I go camping. They need a heavy half version or camper special half ton and get rid of the 2500 IMO. No need for it seeing as they offer a CCSB 1 ton.
Still waiting for this and the 6.6 gas to become available up here.
I really hope fabtech got their engineer team on point. They built sturdy stuff but geometry was all over the place.
Shocks are “meh” as well but only if you are wanting to push them like a fox or king shock could be. Most people won’t have that issue. They are a step up from fox silver cheap shocks though
