Finally ordered mine
N2BRK
2,393
733
it only took me how many years to finally make that turbo sock move from cart to completion? LOL. Looking forward to getting one!
N2BRK
2,393
733
And only 6 months to install it. Lmao. I put it in last night. Easy as pie. Can’t wait to put a few miles on!
N2BRK
2,393
733
Wow, I can actually feel a difference, and my EGT gauge notices one too. I'm surprised. I noticed that my turbo actually lights a hair faster. I have a tune that has a little lag just off the bottom, and I felt it cleaned up a bit and lit faster now. Very cool.
Any sense in trying to run a sock on the cold side pipe and/or hot side? I'd like to do up-pipes one day, but I cringe thinking about taking them off again! LOL.
Oct 16, 2008
951
21
Idaho
Sorry! I flat out didn't see your posts but I'm glad you're liking the blanket!
I wouldn't recommend blanketing the intake pipes. While it might be beneficial for a short amount of time, eventually they will get heat soaked and work against what you're trying to achieve in the first place.
You're better off keeping the heat at the source and letting the pipe bleed heat to ambient if it needs. IMO
N2BRK
2,393
733
great advice, thanks. Somewhere in the back of my mind, I remembered you making a set for the Elephant, but I didn't find any update as to effectiveness... should have been my first clue :roflmao:
Oct 16, 2008
951
21
Idaho
I'm not sure that I've ever knowingly made a set of intake blankets. Not that I wouldn't. I just try to share my experiences so someone doesn't waste time/effort/money on something that might not work all that well.
N2BRK
2,393
733
That’s true! Remember the motor mounts making the handling better :D He was cool. We exchanged a lot of emails and texts
4,847
1,894
I could see that being true on the generation of truck Mike was working on. Those older square body frames are flimsy compared to what we have in our factory equipped duramax trucks.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
He was a unique individual, I thought he was annoying until I met him in person then I realized yes a dually a cool dude, still weird though.
I still got some conveyor belt in my shop with his name on it that I got from work that he was going to use to make an air scoop for his trans cooler
Columbus450
260
Louisiana
And you didn’t have to remove the turbo for the blanket?? I’d be interested in one for my LBZ
Update
Never mind I just checked out the guys website looks like they’re held in with ties
ZeroGravity58
1,427
56
Maryland
Update
They work great I just installed mine on my 68 valley charger and on my s480. The blanket on the stock charger is held on with stainless ties. I bought them to help keep the underhood temps down, after a hard run I can pop the hood and lay my hand on the blankets with no problem
Columbus450
260
Louisiana
Wow!!! That cool huh, I need one for my 65 3794 Do you happen to have any good pics of yours
Sent from my SM-N960U using Tapatalk
N2BRK
2,393
733
Levi - do you think that I can install your up-pipe blankets without pulling the up-pipes? The EGR riser is cut off. TIA! Wally
4,847
1,894
Is your transmission out? I installed mine with the up-pipes installed but my downpipe or trans was out.
If your downpipe was out but everything else was in you COULD do it but man it would be terrible and take way way longer than it should. The drivers side is the biggest nightmare when the trans is installed due to the lack of access compared to the passenger side.
