8,051
Yup, Profabs.
i had a real hard time not throwing a set of dmaxstores manifolds and up pipes on for as cheap as they were but the whole point of changing the up pipes was for reliability. im going to start pushing these turbos pretty good once the new truck is here and i dont want a blown up pipe from drive pressure. Had Rick keep the pass side from being squished as well since i dont have a downpipe to contend with it.
Seriously Albert. The only way i could have sold it was out of state and even then, if they joined this site, id have to pay off Kat and Pat so i could ban them. i dont want to see that shit!
8,051
More parts
Oil pump
L5p oil cooler. Pretty damn big difference between my lb7 and the 17-19 L5P! Can’t imagine how much bigger the 2020 one is
Ridin'GMC
I like red
May 20, 2010
715
50
MA
That l5p cooler will definitely help your cooling issues in the hot summer days of towing. Pretty sure all the stuff you got is going to last you a while without issues.
8,051
I’ve only been saying that the last 15 cooling mods I’ve done
How is it going to be mounting it up James?
Should mount up just the same, just gunna need a few longer bolts to mount it to the block. Where the water pipe goes in and the elbow attaches is the same.
c5fourj
Occasionally moving quick
Dec 20, 2014
307
Brighton, CO
More parts
Oil pump
Did you need to buy all new gaskets, or did they come with the cooler? Also, did you just pick up the cooler from the dealership?
13,862
966
I will never understand why Callies cuts those double keyways in the crank for the balancer.
