03' GMC SoCal stroker
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I ended up tapping coolant cross over and am re routing the heater with 12an hose to get it out of the way on the top of the motor.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I found these 90 degree quick connect heater hose fitting that work with these heater core outlets. The factory straight fittings point almost straight into the exhaust crossover pipe.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Picture of the re routed heater core lines. I still need to shorten the oil drain line.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
One line from the heater core goes into the bottom rad hose, I see that one. Where do you have the top line going? It should go to the top of the thermostat housing. Am I missing something???
I tapped the coolant crossover and running the 12an line over the top of the alternator and down.
ZeroGravity58
1,427
56
Maryland
Ah ok, by chance can you post a list of everything you used :D my trucks in pieces right now and I got rid of the line that runs up behind the motor so I'm looking to relocate mine :D
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
- 10ft of 12AN hose
- 2 Gates 28505 90 deg quick connect fittings
- 1 90 deg 12AN female hose end
- 3 straight 12AN female hose ends
- 1 90 deg 12AN male union
- 1 10AN to 12AN straight male union
- 1 10AN male straight push lock
- 1 12AN to 1/2 NPT standoff
Or you could use the Gates 28504 fittings and 5/8's heater hose and barb fittings.
hntngkd
162
Attica, Mi
I had used the same fittings when I first installed the compounds on my truck and I had an issue with one blowing off constantly during high rpm pulls. I tried a ton of different ones and they all did the same thing. I went back to a straight one and it solved all my problems. Just something to keep an eye on. They felt like they snapped on fine but more than a handful of times I had one of them blow off. Im not sure what was causing it, if it was just the sharp 90 and there is too much coolant flow through there or what.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Good to know...
I'm a machinist by trade, and have been thinking about making some billet ones that will accept 12AN fittings.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Built some traction bars, made from 2" DOM 1/4" wall with Ballistic fab poly joints.
