DHD Brace with leveled truck
LBZ_Baker98
208
Texas
my lbz has cranked bars slightly. truck isnt totally level still sits about a inch lower in the front. I bought a DHD brace so i could run it leveled on the street and lower it for the track like i have seen and heard of some others doing. How ever my brace wont fit. with it bolted up to the center link the brace hits the front dif. Anyone running a DHD brace with a leveled truck. I called DHD but still waiting on a call back from tony
darkness
1,586
613
vegas
Exactly how much is it hitting the diff? The brace rides along the diff. That’s what provides the support.
darkness
1,586
613
vegas
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I may be having a moment. But isn’t the center link in front of the diff. So the nylon is supposed to be towards the centerlink.
Edit: oh wait the brace bolts to the centerlink then the nylon rides the diff right?
snowman22
301
SoCal
The nylon rides on the diff and is what supports the brace. Some trucks the brace doesn't make contact and there is a small gap. It then makes contact under load.
THe LML brace is different and rides on a roller. So it depends on the application.
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I had to think about it for a minute :spit: you treed me on my edit :roflmao:
SoCalMike
851
79
California
I thought all years had the roller option?
From what I remember if your cranked too much in the front the tierods will hit the dhd brace when turning at close to full lock. I could be wrong though.
For me I like the cognito brace for leveled trucks. If I was lowered I would go with the dhd brace. For a stock truck that wanted bracing you could go both ways.
Go ahead James and school me. Lol
8,236
Ive tried it before. It doesn't work properly on lifted trucks. It works for factory height trucks. If it does, I must of installed something wrong myself as well.
Even says it in the description
https://dirtyhookerdiesel.com/i-149...-center-link-steering-stabilizer-bracket.html
Think about this. Why is it a lifted truck (one that uses drop brackets) will not work with this bracket and why is that I’m saying a leveled truck (op’s truck) will work with this bracket?
There is a slight slight chance the op is using a lift kit and lowered it to leveled height but 99% of the time if they purposely did that, they will say that because that’s pretty specific information and knowledge
Yngdmax92
962
I know you know suspensions very well. But even on a leveled truck like I am assuming the OP's is, where the brace does bolt up and look good and act like it's going to work. It just doesn't work. It was not built for leveled trucks.
8,236
Huh? The brace works for its intended purpose on leveled trucks as well. Ive seen them do just fine on 2 leveled trucks I’ve worked on. If you are expecting it to stop all toe in, it will not do that as the flex comes elsewhere but the idler/pitman arm won’t rock. That’s its design.
Again, this will work on leveled trucks. NOT on dropped diff lifts. Dhd warning is specifically for those type lifts.
Yngdmax92
962
I personally don't suggest them for cranked keyed trucks. But, more importantly will just have to see what the OP gets for a Response from DHD. :D
8,236
Out of curiosity, what do you recommend for a leveled truck that doesn’t want to drop the coin on a krytonite centerlink kit?
3,930
829
Like James said, on a factory located front diff the bracket will bolt in place and serve it's purpose regardless of how much the keys are cranked. Obviously the more you crank on them the less effective it will be.
To the OP, what pitman / idler arm are you running? That's the only reason I can see why the bracket might be pushed farther back toward the diff.
