67 c10 duramax build
TMAN
95
29
Haven't updated in a while but driver's side rust repair is done as well as the cab corner on passenger side. I still need to finish the floor on the passenger side and replace the rocker. I didn't find any rust on the rocker until I pulled the weather stripping off so may as well replace the whole thing.
Sent from my PH-1 using Tapatalk
Jacy_dzlguy
lots to learn...
Aug 27, 2011
257
33
South Florida
Looks good! My dad and brother did the same thing with a 71 and a 96 4x4 cummins :) we’re not smart enough for all that Duramax wiring :spit: We had to do electric fans and do a lot of figuring to fit the front core. The rest was pretty straight forward..:coolspot:
TMAN
95
29
That would be a cool project too. Dad has an 89 Cummins 4x4 that we plan on dropping a 40s international cab on top and putting an 11 foot flat bed on for a service truck on the farm
TMAN
95
29
Rust repair is done just need to smooth out the welds.
TMAN
95
29
Also did a sas with a wfo 3 inch kit and super duty axle.
TMAN
95
29
Where it sits at the moment. Front half of frame is coated in rust barrier under coating. Axle and radius arms were painted with implement rust stop enamel primer and paint. Axle hubs redrilled to 8x6.5 pattern.
TMAN
95
29
Oh man.
This escalated quickly suspension wise. Lol
Can’t wait to see it all done
Control arm mounts were twisted and enough other components in the front end were broken that it wasn't too much more to just do the sas.
TMAN
95
29
Also engine got a welded water pump, new front main seal, new upper oil pan(front dif was pushed up into it), lml driver side manifold, new passenger side up pipe, power steering pump, thermostats, and I think I'm going to get new idler and tensioner pulleys.
TMAN
95
29
Shaved firewall where the heater box mounts
Modified the brake pedal to mount it in the 67 bracket and mocked up the dash and steering column.
My professional driver lol
TMAN
95
29
Finished filling holes on the fire wall.
Painted the brackets for the steering column and brake booster
And started shaving the rust starter lol
TMAN
95
29
Day 2 of shaving the drip rail, this is going to take a while
TMAN
95
29
Trying out this YouTube thing. This is what I have for videos so far
[YOUTUBE]iftQU-jhZzM[/YOUTUBE]
[YOUTUBE]Ya8MdqCP3s8[/YOUTUBE]
[YOUTUBE]sOQcx6OL21k[/YOUTUBE]
rickcdewitt
Jun 6, 2017
93
State of jefferson
Sorry to see your starting pic. I recently did something similar to my 02 ccsb lb7. Since I'm looking at putting another body on my truck at the least this conversion has also been on my mind. I have a 70 k20 but I'm not keen on a body lift or the wimpy frame with a 1000 lbs of torque.It looks like it fits pretty well.
How much did you chop out of the middle?
And what are you doing for a heater?
TMAN
95
29
It was 26-27 inches I cut. Going to use a vintage air kit for ac and heat.
TMAN
95
29
Haven't updated here lately. Made some progress tho.
Finished the drip rail and filled the seam on the cab roof
Finished up the body work on the cab and doors
As it sits now. I have the front cab mounts done, rear cab mounts are marked out and just need to be cut in and then welded when the lift is available again. Doors are essentially ready for primer. And I've started working on the box
And made a new video update
https://youtu.be/FxfffquWXoA
lutzjk
1,930
378
groveport, ohio
Is it me or does the cab and bed lines not match?
Your skills are amazing man. I wish I had that knowledge and patience. Keep it up.
