New tunes
PapaBravo
Jun 3, 2011
67
Redlands, CA
I have made some changes to my truck and would like to update my EFI Live. I have had the transmission rebuilt, added a lift pump and changed the turbo to a Garrett 4094. I would like to hear any suggestions that you might have.
3,058
What year truck?
Are you looking to make the changes yourself or someone else?
Stock injectors?
What are your HP goals?
Give us a little more to work with and we will be able to help you better
PapaBravo
Jun 3, 2011
67
Redlands, CA
It's an '06 LBZ, with stock injectors. I'm not looking to making a lot of horsepower. I just want to maximize what I have now. Currently it has tuning from The Neens. I sent him a PM, but I haven't seen him on the forum lately.
3,420
Moved to Tuning section.
Well, if Neens never get back with you, there's always Tony or Mark.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Chris doesn’t get on here but every once in awhile. If you like his tuning I can text him to ck his messages on here.
PapaBravo
Jun 3, 2011
67
Redlands, CA
"Chris doesn’t get on here but every once in awhile. If you like his tuning I can text him to ck his messages on here."
Thanks! That would be great.
3,058
They put in a billet 3500 torque converter and a trans go jr
That is definitely not a built transmission. Your new turbo could easily make enough HP to ruin it in a very short amount of time. Keep it under 100 HP over stock if you want any life out of it
Until then, start saving up
monster50iii
339
11
About all you'll need is an update in max vane tables desired vane tables, and some lowering of desired boost in the lower rpm/mm3 areas being it will be quite a bit more lazy than the stock turbo. May even want to pull some pulse to be safe etc..
