Airdog 165 pressure
Philv
Jan 30, 2018
117
Surprise, AZ
Ok installed it when I did my injectors about a month ago. First primed start up I had 12.5psi got the p0089 code. Erased it and lasted bout a week before it came on. Now my pressure has raised to 15psi and I get the code every could of days. Is it normal for the pressure to raise by itself? And what should the pressure be at? With code active, truck run perfectly normal, I just have the mil light on. I've been searching and can't find anything about the pressure rising by itself.
ZeroGravity58
1,383
46
Maryland
You can adjust the pressure. There is a screw on the side of the airdog, turn it down until you get the pressure you want
1,740
Try dropping it to 10 psi and see if that helps. A little above that and some will start to have rough idle or codes, etc. Unless tuned for the higher pressure. Then when you get closer to 20 psi you start to risk leaking from the fcim
Philv
Jan 30, 2018
117
Surprise, AZ
Fuel temp plays a role in pressure.
Yeah I noticed that today. 15psi first start up, once warmed up it dropped to 13.5-14psi. it runs great at that pressure. No rough idle, no noises just the damn light. Also when I go full throttle it drops to roughly 9-10psi. Will dropping the pressure to 10 at idle hurt the top end performance?
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
No. As long as you have 1 psi or more you will not loose performance.
