About how many hours it take? I'm sure next one might be quicker.. I ask because I'm thinking of having a friend of mine who has a shop do mine for me
From driving a stock truck in the shop (already had exhaust, but had full egr) to backing out of the shop, with fass and sump install 7-8 actual working hours. It went very smooth.
beach_33
704
des moines, IA
I can only imagine the paper work for a critical pick like that. Safety was probably freaking out. I can’t see the size of either crane but I’m sure even in a tandem lift ( which I’ve never seen done quite like that) like that they were probably pretty high on their chart. An 18,000 would’ve been sweet and well within its chart as long as configured correctly. Sweet picture man
hondarider552
Getting faster
May 28, 2008
10,627
35
Arizona
This panel was incorrectly quoted on weight, reason being a tandem lift.
Cranes are Grove 550 ton (out as a 450) and a Liebherr LR1300 330 ton
3,420
The thing that gets me is all that weight is still being concentrated thru that one point between the span connected to the cranes and the smaller span above the panel. That is crazy. How can that be safe?
hondarider552
Getting faster
May 28, 2008
10,627
35
Arizona
Those shackles between the spreaders are rated for 350 tons each. Use two spreader bars, the upside down one can change heights in relation to how much cable up or down each crane gives the bar, and the lower bar will stay horizontal as the pick points on the panel dictate that. This was the first time I've seen that bar done, but makes sense so that both cranes share the load
beach_33
704
des moines, IA
It’s safer than you think. It’s all about your training and certification. But even with those you still get very anxious and nervous your first few critical picks.
Even with the way That’s rigged with upper spreader bar being free to move up and down from end to end ideally it stays flat the entire lift.
Wish I could figure out how to post pictures off my phone. I have some pretty cool ones
BrandonLLY
119
9
Emergency 2” gas valve replacement for sdge.
Steel valve was leaking in between the two pink pipe ends that I had to cut out after making bypass with new PE valve.
1,456
Snagged this up 97 C3500HD 139k 454/nv4500 for 1500.00.. burban isn't like the weight much..34" tires and 3.73 gears 4th is useless:rofl:
Current slot is backup/rescue truck probably swap a diesel into it down the road
six5creed
1,046
58
N.C.
Went and bush hogged at the farm yesterday, lost money on this job again. Hole about the size of a quarter this time. These tires are pretty tired, they been on since 1993.
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
Playing catch up. Finally got some revised drawings. 13 floors of elevator retrofitting, has to be done in 36 days. Going to be a long month
Sent from my SAMSUNG-SGH-I537 using Tapatalk
