1,514
I talked with my brother the water expert. The Rydlyme will work on the calcium. HOWEVER, you will need to add a defaming agent (available at pool or hot tub store) as the breaking down of calcium will cause hydrogen and carbon dioxide release which will cause the foam. Also, you will need to remove the thermostat or it will capitate and eat itself up. After you get the desired results, you will need to do multiple flushes to get rid of the residual Rydlyme as it will destroy the antifreeze.
Check out the other stuff I suggested as it will work the same way, still needing the defamer and no thermostat.
With either of the chemicals you use, if its possible to flow the water without running the engine it will work. In any case as temp of the water increases so does the chemical reaction to convert the calcium. Be careful as if it gets up to op temp it becomes detrimental to aluminum. Recommended max temp 120F will make everything be happy.
I have no effective way to circulate the water/chem mix without running the engine..
Thanks!
Better pic once everything dried out.
Hambone
Always learning
Jan 24, 2016
591
20
Florida
Glad to hear the east coast is busy too, we have two of these Liebherr crawlers and they are both booked till end of the year.
Florida is going up scary fast!
Been on several 400k+ sqft warehouses in the last year
The frightening part is they have whole side walls only being held in with 4 panel to footer connections and roof PA that’s attached to the deck via shot pin!
Asked the superintendent one time and he said the Caulked seem is an attachment also:roflmao:
jlawles2
1,126
66
Danbury, TX
Thanks!
If you can put an inline pump on the heater circuit, that would circulate the product. I think HF sells a cheap rubber impeller pump that you could plumb in. Hopefully most of the stuff came out with the liners.
1,514
I vacuumed all the flakes up with a shop vac..took a brush and air hose to get alot of the loose stuff out... finally figured out coolant path through the block..
5,101
703
Beating my head against a wall trying to get a Subcontractor in this facility. This is my third attempt and been trying to get it done since May. It’s for 30mins worth of work. If there is a 4th attempt I might just say they’re only making a delivery not working.
1,514
Got 5 correct liners installed tuesday night,called Wednesday morning that 6th liner was packaged/labled incorrectly, the ship new one out gets here 1630 Thursday, can't get to it till 1730 it's wrong as well.. call this morning raised mild storm about it.. supposededly correct cylinder liner should be at my house 1330 tomorrow..
Call up the company just to listen to them tell you how they understand costly down time and they are the guys to reduce said costly down time :mad:
3,590
Got my ass kicked today. 166 stops, 196 miles. 12.01 day. Im surprisingly not tired, but could really use a beer.
1,514
Loaded yesterday
Delivered in NRL naval research lab, this morning
This guy kept up with me high tailing it out of DC including most of the hills on 70 manage 10.17 MPG from Dayton Ohio to DC to Hancock MD
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Load tested our Liebherr 1300 crawler crane today to 105% of capacity.
55k lbs at 138' radius with 154' if boom. Damn boom was flat out and still kickin ass
jlawles2
1,126
66
Danbury, TX
That's hilarious because I know what your talking about
I'm an engineer who lays out lifts and such. Was on a job with 94k hanging on the hook at 400' radius when they called for 1/2" swing so they could make up the bolts.
Been on the deck when survey tells us we are 6" out of level and we hold with no movement for the duration of one stroke and call for a new shot. New shot says we are out of level 6" the other way (no movement of piece by us), then client tells us to start lifting and keeping it level the way we know how. 300' tape hanging down is faster and more reliable than survey. Survey complained that they could not get a reading fast enough.
