8,052
Trans died today. kinda out of the blue and by no means a simple fix.... gunna have to actually tow it out to mikes. :(
8,052
nope but i have a feeling the sump filter is packed now. just before my big trip over labor day, i did a full check up on the truck (fluid levels and smells, oil change, lube, check over suspension and steering) and the fluid looked great and she shifted great. parked it till oct 21st with some drives to work here and there, no issues on a day trip to the dunes and back (400 miles). parked till today and horrible tie ups when up shifting or down shifting, converter stayed locked even at a stop (almost killed teh engine then unlocked), limped about a mile from work, reverse clunks and shutters, first gear shutters and nuetral trys to move the truck, pump whines bad and there are some not so good noises going on. P0776 and P0742 when it limped. checked fluid level at work and it was 1/2" below the hot cross hatches but burnt to hell. If i get time, i may drop the pan but im not planning on it. its not good either way
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Oh wow. Yeah definitely no need to try and diagnose. Time for a tear down unfortunately. Sorry to hear that man.
SoCalMike
851
79
California
That sucks man. Wonder what happened? Could you pull the trans and take it to him? Do you have a means to flush the coolers at home if you did that?
8,052
i was pissed at first but ya know, im hard on the old girl. i have to expect these things.
na ill just take the whole thing out there. i dont have the time to R&R it. i could take it to my buddies shop here that has the machine but just more time i dont have. Get it done at mikes, swap the tow rig i use to get it out there for mine on the way back and get the tcm learned for my Thanks Giving trip :D.
this is assuming the truck can be fixed that day
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
It kinda sounds like converter failure. I'll bet it failed first and the debris it sent everywhere is wreaking havoc on everything.
8,052
7b4cd0f60d4e40b921b8692541ec045b.heic
Loaded up and ready to head out tomorrow after work. I really don’t like this look....
Dvierra86
156
Blew it up again. That’s all pcv blowby along the side of the truck.
2006 CCLB DRW 6"fabtech 35"s 4.11 w/arb sdp 475 over stock 30% ii nozzles fass150 built trans
Dvierra86
156
Who does your tuning??
One of the couple big wigs. But no need to bad talk them, it’s my driving habits. Stock engine 62psi and a 9000lb truck acting like it’s a corvette haha
8,052
#bigtruckproblems i only say this cause we are in the same boat... well sorta :D
Dvierra86
156
I pooped a piston in original engine with a 4094. So found a smoking deal on a junkyard take out engine stock also and did compounds and bigger injectors hoping for safer tuning and longer live and it blew a cylinder in under 4 months. So now time for a fancy bottom end and put her for sale lol
Codykeen09
Nov 15, 2017
Philadelphia ms
I'm sorry I'm new to this and haven't figured out how to work things on here and didn't want to mess up someone's forum but I had a question my last oil change I used two quarts of Lucas oil stabilizer and started getting a engine whine couldn't figure out what was causing it and last oil change I drained the oil and had fine metal looking particals in the oil so I just put my normal oil back in and the whining stopped did I cause damage to the engine
