Finally made some passes.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
well I got my shit together Friday and made some passes at renegade raceway in Yakima. first time I've been down the strip. I was pleased but I have some setup work to do now and better tires, 2nd gear start in the trans tune. in the video you can hear the tires clawing for traction well past the 300 ft mark. I know I know lol I need to work on my launch and reaction time.
https://vimeo.com/218674819
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Drop that 60ft and you will have some solid numbers. Your trap speed shows you are making decent power. Even with first gear start you should see good 60fts. But you'll figure it out once you get more passes in.
catman3126
Jul 24, 2012
2,636
NE Oregon
Thanks guys. I just put new Toyo Proxes it this morning and will be shopping for slicks and wheels to bolt on it soon.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Thanks, I see we're close to the same, what' your weight with your setup?
I'm not sure what it weighs haha I haven't done much weight reduction still have full interior. Hahaha ill have it weighed next week, I got talked into pulling it at the local fair.
catman3126
Jul 24, 2012
2,636
NE Oregon
well in that case weight is good. I believe mine is around 6800 still, might even be more with compounds on it as I haven't weighed it with those on there.
Chad006
Drag racer wannabe
Feb 12, 2015
311
Goodlow, B.C.
Congrats on the pass! Looks like it'll actually run reasonably clean once you get your launch figured out, considering what you've got for fuel.. What converter are you running?
