x2.
the alignment machine doesnt care about tire size, thats not how it reads toe.
Drives straight and I did it this way so When I do install larger tires I don't have to scuff my new wheels with the machine redoing the alignment. As toe will change due to larger circumference.
Hadn't had the truck detailed in years. Took it in, clayed barred, polished, waxed and detailed inside. Don't lean on the truck, you'll be on the ground.![]()
X2 My 2001, with the Indigo blue is still in good shape except for the hood. I contribute this to the heat the trucked endured during the summer and engine heat output during the summer.GM paint is amazing stuff if half way cared for. I've seen 15 year old trucks that look almost new.
Wait so a company will build mega cab chev for you?
2008 gmc sierra 2500 lmm
the toe change from the larger diameter has no affect on the toe that was set with the machine. yes, as tire diameter increases in size, it will amplify the difference from the outside of tire diameter to outside tire diameter from the forward facing tread and the backward facing tread. But that is a mute point as the machine is measuring from a consistant point every time using the heads of the machine that are put on. so you could put 40s on it, but the machine will still measure a certain point out from the center of the head and report it back to the machine. even the slightly larger contact patch doesnt matter as most machines measure beyond the contact patch so it is not too touchy nor would it create issues with wear.
what you SHOULD compensate for with bigger tires is more caster, not toe. that will help the turning of the steering wheel in return to center situation, help keep the truck tracking straight better and fight the higher weight and circumference.
you have a good thought, you are just applying it in the wrong area
Wow is this yours?Stretch My Truck
Here is world first functioning mega cab!![]()
Did a parking brake cable flip and installing the blocks.
It'd be best if it had an 8ft bed as wellStretch My Truck
How do you like the ride with those King shocks?
Lost my Oakley's in its engine bay...
Lol bad deal. I can never get oaks go last or I lose them.Lost my Oakley's in its engine bay...
White framed? Thats just too bad....
:roflmao:
