I starts fine, let it warm-up, put it in gear and it stalls. If you don't put it in gear, but very, very, very, very slowly press the accelerator, the engine looks and feels like it is going to break the engine mounts, with vibration. If it is not put in gear and the throttle is press "Quickly" it stalls. It always restarts perfectly, it idles fine.
It will idle fine for as long as I will leave it idle, 15 or 20 minutes and it idles fine, feed in just the slightest power and it stalls. It ran fine right up till this started happening. Never any engine problem till this. I removed the air filter to see if that would make any difference.......it did not make any difference.
Before this it never had any visible exhaust....none. Now there is a blue'ish exhaust, if the power is feed in slowly, till it looks and feels like the engine will jump out.
Engine and Truck has a total of 35,800 original miles
Fuel filter was just changed about 500 miles ago.
Thanks for help.
Thanks for help.
