Looks good man.
Where abouts did you find the wire harness behind the bumper exactly? I should go look at mine.....I did some more looking into the truck for the fog, the wiring seem to be there behind the bumper but haven't looked yet behind the dash, hopefully it is. I tried hooking up to the ECM and just as I suspected, the ECM is locked so I'll be needing a stock tune. Wasn't able to see what OS it is.
Just directly above the lower valence under the radiator support.
Yep, there's little tabs to clip them back out of the way. I had to buy the little harness from the fuse panel to the switch, but double check first.
I'll definitely check on that. Probably this weekend, it's damn near impossible to get things done when you have 3 kids under 5 years old.
Thanks... I'll check it out when I get a chanceJust directly above the lower valence under the radiator support.
I just had my first baby. He's 12 days old. I finally got 65% of my yard mowed and 70% of my trees and branches cleaned up after two weeks off.
I could only imagine having 3 youngsters, they always want something and you always want to give them all you can, I see my wants going downhill quick, lol.
I believe I found them, drivers side was tucked under radiator and passenger side was tucked around the horn. I gotta pull the dash cover off and look to see ig I have a harness going to back og where the switch would be.Just directly above the lower valence under the radiator support.
My cargo switch has 6 wires coming out of it. Does that sound like I already have the correct harness for the fogs switch? Or does the switch for the fogs have it's own harness?Yep, there's little tabs to clip them back out of the way. I had to buy the little harness from the fuse panel to the switch, but double check first.
Haven't been here in a while. I lowered mine 3" and love how it looks. It doesn't ride too bad towing either with it lowered too.
gay..... needs long travel :roflmao:![]()
Oh so you kept the white truck?! Hell yes!
Sure that's easy peasy since you are making arms. We can change some things to help the shock/spring work better.
My cargo switch has 6 wires coming out of it. Does that sound like I already have the correct harness for the fogs switch? Or does the switch for the fogs have it's own harness?![]()
